TwinTurbo.NET: Nissan 300ZX forum - I've been busy with work...timing belt has to be off somehow
WVZ
on April 26, 2008 at 3:59 AM
You figure it out yet? (n/m)
posted by Waggz
on April 25, 2008 at 09:17 AM
....I've ruled out everything that I know to rule out, and I'm to the point now that I'm just gonna tear it all back down this weekend and start over. If off-time was the case I guess im prepared for possible bent valves :(
Very sorry everyone, this should probably be in tech, but
WVZ
13:40:07 04/23/08
No - as long as there are no issues when you turn it by hand
Dave N
13:41:12 04/23/08
2nd, you good to go....
Sleeper_TTZ(SeKy)
14:04:08 04/23/08
Did something happen, or are you just being cautious? (n/m)
Waggz
14:06:56 04/23/08
Check his tech but basically he did a timing change, wouldnt
5280Z_nightstalker
14:27:37 04/23/08
btw nightstalker, while I was searching I came across some
WVZ
14:33:44 04/23/08
If you have the new Mitsu style PTU then I want to say you
5280Z_nightstalker
16:47:51 04/23/08
got everything put back together after timing belt change,
WVZ
14:30:28 04/23/08
my first guess would be either injectors or ign packs
Waggz
14:33:39 04/23/08
Did you gap the plugs before the timing belt change?
doug8867
16:41:04 04/23/08
Yes, if lifters were collapsed and pumped up after start
Fast300
15:57:48 04/23/08
Waggz
09:17:24 04/25/08
I've been busy with work...timing belt has to be off somehow -
WVZ
03:59:09 04/26/08
